Refurb Msi 7850 2GB not working correctly
10 Mar 2012
Installed this gpu today after playing for few hours I notice artefacts and then screen turn like this
Then error
Sometimes white screen, sometimes monitor will switch off and I need to restart computer, or message "display drivers stopped working"
have you tried other driver version? if you have I think you need to return it. Refurbished man, can expect too much.
yes I think because it worked for couple of hours fine they didn't pick it up, on hitman it was going all over the place, but on different game it happen once and then it stopped, will play with drivers and if it continue will send it back
Probably the program that is rendering the photo will use some form of hardware acceleration on the actual image.
Return it under the 90 day warranty mate, I doubt it's any other component. You could try a BIOS update I suppose, but that's almost guaranteed to the the graphics card.
