Hello everyone,
I have a laptop that I used through uni (Fustisu Siemens Amilo 1520) that since receiving a laptop for my job, has sat wasting away as a 4od/iplayer/mkv player.
I now want to get it back to top working form!
As it has sat with the charger in pretty, much non-stop for the last year, the battery is propper dead! so I intent to purchase a new one, however I will continue to use my old one when it is plugged in for long periods.
The computer is starting to get very hot when running and very often the fans have to go into overdrive to disapate some of the blistering heat that it develops, this had lead me to want to give the whole thing an overhall, but what can be done about the fans?
Also it is running a lot slower than it used to, so i would like to clean the circuits to get the most back out of it, but I am unsure what to use... I assume rubbing alcohol would work, but not sure, any suggestions.
VMware installations. Once the hardware is back toegther (and hopefully still working) I aim to run VMware on it, to give me different desktops for CAD (Win XP), Media Centre (LINUX MCE), Electronic CAD (Fedora), normal surfing (Win 7). This is so I can reduce the likly hood of me having to remove all the files that build up before re-install an OS.
BUT, I have never done a VM ware installation! Basic questions... Can I install VM as a base installation, or so I have to install an OS to install the VMware into? if I allocate all resorces to the a virtual machine, what will the speed difference be between the VM and if I had just installed the OS directly. Which VMware product is the best to use?
Any other suggestions how to maximise the power that I can get but still maintain the flexibilty of VMware?
Cheers
Ste
Cheers
Ste
