Basically the screws will mash the fins a bit, as long as it doesn't drive into one of the flat tube veins, it will not leak. It looks better without the washers obviously but if it worries you then the washer solution is good (or cut the screws). Seen this problem many times and never had one leak and i do not bother with washers/cutting the screws down.
