I use Reg seeker have done for years as i find it good and free
but i also know most of these apps don't pick everything up that
should be deleted and you should run 2 or 3 different ones most of the time.
I used to use reg cleaner as well but for some reason that doesn't work anymore can't even run the thing.
Which reg cleaning apps do you all use or have found to be good.
I try to stop it at 99% and clean the 1500 its already found but when you close the program it has some errors in french and doesnt delete them. (i have run the program with admin rights)
