Hi, I've just built a PC for a relative using the Akasa Zen case. There seems to be a flaw in the build? On installing the optical drive behind the first steathed bay, as soon as you hit the button to eject the drive, you can't close it again because the flap comes down and blocks you from pushing the button.
So instead, I've just dismantled the flap so that I can actually close the optical drive using the button instead of using force to push it back in.
It's a shame because the build quality is very good... unless there's just something wrong with my case?
