Caporegime
- 9 Nov 2009
- Planet Earth
OK,regarding sensor size,a good article to read up on:
https://www.ephotozine.com/article/complete-guide-to-image-sensor-pixel-size-29652
That is the difference in physical surface area between a 35MM frame sensor,and an APS-C sensor. Its over 2.27 times bigger.
Having said that the actual metric you need to look is the photodetector size.
So a 24MP sensor like that in the D600,D750,various Sony cameras has a 6 microns pixel size,and the 16MP sensor like in D7000,XT1,etc is at 4.7 microns. A 24MP sensor like in the D7200 has a 3.9 micron size.
Assuming things like similar technology levels,stabilisation and similar equivalent light amounts,this is why full frame is generally "better" in low light and wider DR situations,as each of those photodetectors has more surface area and can detect more photons of light.
How does this related to noise?
Noise is a by-product of the semiconductor technology used to make sensors - in terms of a "digital sensor" it is basically an electrical signal not produced as a result of light hitting the sensor.
Some of this is down to temperature and some of its down to flaws in the physical characteristics of the sensors themselves.
Why is more light then important??
Its all about the output electrical signal - if there is more light the signal is larger and it swamps the low level "aberrant" signals produced as a result of the factors behind noise.
Less signal,ie,in low light and the difference between the signals is much less,and it is further compounded when its amplified to try and produce a usable signal.
Even the 36MP and 42MP 35MM frame sensors have larger pixel size at 4.9 microns and 4.5 microns when compared to a modern 24MP APS-C sensor.
However,as I mentioned technology levels can help. You heard of things like microlenses?? They are there to try and collect more light,and the same goes with more sophiscated mechanisms to try and process the image in-camera,or more sophisticated amplification mechanisms,etc.
Another factor is that even if you have a pair of F2.8 lenses,the physical aperture on the full frame lens will be actually physically larger(you can test this by manually opening the aperture on two lenses and looking at the actual diameter of the opened aperture).
So take it into to consideration if you are really interested in low light work!
