Suspended
- 18 Dec 2007
http://www.enigmasoftware.com/support/antivirus360-removal/
If you scroll about half way down you will see this title
Antivirus 360 Manual Removal Instructions
on Step 2: How to Delete Antivirus 360 Registry Keys and Values.
Following these 10 steps is suppose to delete the registry entries but I dont see how because there is nothing saying delete its all, it only says its adding things to the registry???
I can only think because the file will be called "Delete_Registry_
Antivirus 360_Entities.reg" is that telling it to delete the things from the registry?
Any help confirming this will delete the relevant entries will be very helpful.
