Regex help needed please.
17 Nov 2003
Gateshead
I've turned my hand to a many, many things development related but regex continues to elude me!!
I need a regex to match filenames with extension where the filename part before the extension ends with a '-'.
Some example filenames...
filename-.png <-- MATCH
file name.doc
file name 3.mp4
file name -.dxg <-- MATCH
file.name.mov
NOTE: The filename may contain any valid character including periods.
Many thanks in advance :)
Depending on your development environment you could also just get the filename with the extension removed and test whether the last character is a hyphen, e.g. for c#
if(Path.GetFilenameWithoutExtension(filename).Last() == '-')
//do something
Regex is probably cleaner, but may be cumbersome to cover all edge cases, especially if the filename may also contain periods
regex101 is a great resource for learning about regex's. Once it all clicks in your mind it's really straightforward... just looks daunting to begin with :D
file name.doc
file name 3.mp4
file.name.mov
This does what you want. (Python)
Code:
import re
tests = ["filename.jpeg",
        "filename-.png", # <-- MATCH
        "file name.doc",
        "file name 3.mp4",
        "file name -.dxg", #  <-- MATCH
        "file.name.mov"]
pattern = r"(-\.[a-zA-Z]{3,4}$)"
for test in tests:
    match = re.search(pattern, test)
    if match:
        print(f"{test} : Matched: {match.groups()[0]}")
Output:
Code:
filename-.png : Matched: -.png
file name -.dxg : Matched: -.dxg
Flippy's suggestion help me out. I needed the pure regex, it's for some software that requires a regex input.
I agree there are many ways to skin a cat (c#, python, JS, etc) but I needed a specific way in this case.
Thanks all! :)
