[Regex] How do I find values in brackets...
2 Apr 2004
Melbourne
I am currently learning regex and its making my mind hurt a bit.
Ideally, I wish I could figure it out, but maybe one of you guys could help me.
How would I go about matching the following pattern and pulling out the value between the brackets and replacing the whole lot.
So say I have the following
Code:
{value}
and I want to replace it with
Code:
cheese
how would I do it?
Sic said:
Code:
{[a-zA-Z0-9]+}
will match words and numbers, nothing else
To be pedantic, letters and numbers (words implies more than one word, which in turn implies spaces [not caught by the expression]).
sorry, you're right. I know what I meant, but it wasn't what I said! That should still work for what the OP's after though
yes it does work and it works great.
its for a simple template engine I'm writing and have used str_replace to replace the values I do know and that regex to replace all unset values.
so thanks everyone :)
You may not want to implement this.. what if the users content contains "Blah blah {foobar} blah blah" you'll end up replacing it..
ereg_replace ("{\w}", "cheese", userText)
The following should do what you want. I'm not that great with PHP, but it looks as if that is the regex replace function. \w is short hand for a-zA-Z0-9.
