I'm trying to put together a search to find all procedure calls that are not passing the second parameter.
Here is what I have:
(,){1}.'[^(,)]{0,100}'
it matches the pattern , '<n-100>'
However I dont want to find anything with that so I tried this
\);$(?<!((,){1}.'[^(,)]{0,100}'))
What I thought would happen was that it would look for everything ending with ); and made sure the preceding item was not , ''
This is not happening. I was then going to add assert\(.+ to the start.
Examples of what needs to be picked up
Assert(1=1);
Assert(IsThisTrue(OneParam, TwoParam));
Assert(x = 'Hello');
we dont want to pick this up
Assert(True=False, 'True is not false');
Any reg exp gurus out there?
Assert(1=1);
