Region code...
johnno93 said:
It'll only work if you have a multi region DVD player. UK is region 2 so if its region locked it wont work.
Okay would it work on a PS2? I have a top of the range Sony dvd player, wondering if it would work on that.
Thing is I can't seem to find this box set elsewhere online :(.
For PS2 region unlock, you can use legit Xploder cheat CDs (or other brand). THey usually include a region unlock CD you insert and then remove before playing your film. (£9.99-£29.99)
