Registry Cleaning
19 Jan 2003
Bristol, UK
Can you recommend any good FREE applications which do a good job of cleaning the memory without causing any issues or problems?
Also a similar program to remove unused/temp files which does a better job than windows.
Need versions for 98, Me, 2000 and XP.
Thanks,
Chris
Regseeker. U will find it on badasses website in his sig, he will be hanging around the monitors section of this forum if u want to find him.
Thanks guys.
Something else I keep coming across is dog-slow PC's. They all seem to result from having Norton AV on them.
Temporarily close NAV and they are nice and responsive.
Is there certain functions of NAV that can be disabled so it's not such a hog?
It's been a long while since I've used Norton's/Symantec AV, but they always used up way too much memory for my liking. One thought..have a look to see if they have 'check all files' enabled.
OK cheers.
I ran those registry and file clean up programs on my own computer.
All I will say is, WOW!
