Hi guys, just wondering if anyone can help me out with a registry problem?
I turned my desktop PC on today, and got a BSOD bad system config error. I have searched the error, and ran system recovery and both lead down to bad/corrupt registry. Im pretty sure windows update had installed updates upon last shutdown... but anyway, theres no system restore point either!
I have tried re-installing windows 7, but im still having problems with the registry.
Is there anyway to totally rebuild the registry for windows 7 using command prompt from the windows 7 disk? Anything that will fix this basically!
Hope this is in the correct forum, if not can a mod move it please!
Cheers
Adam
Cheers
Adam
