- 4 Nov 2004
Hi
I did a completely new build of Win XP SP2 last night, and used the very latest Marvell Yukon drivers for the NIC (v 84923). Unfortunately, they have the same problems as some earlier versions.
I have an older version (v 84643) that worked fine. Unfortunately though, I can't 'roll back' the driver for the NIC as it was the first installed. When I try to install the older version with the 'update', I get a message saying it could not find a better match than the one currently installed.
In the ZIp files are .cat, .htm, .inf, .sys, and .txt files. I presume the only one actually important is the .sys file? If I use that in C:\windows\system32\drivers instead of the old one, will that be sufficient?
Marcos
Marcos
