Regular Hi-Fi, AV Receiver or PC speakers?
21 Jul 2008
I posted this in the Sound City part of the forum, but figured it might actually be more applicable here.
So, I have a "spare" pair of Bowers & Wilkins M1 speakers from all my messing about with HiFi speakers. So I thought, rather than stick with my ancient Logitech 2.1 el-cheapo system (Was around £25 15 years ago), I could upgrade a little. I have just put in a Soundblaster Z soundcard into my Ryzen rig.
I also have my DJ decks in my office run off a NAD 310 stereo amp. So I'm looking for a solution for both my PC and my decks.
So I have a few options to upgrade what I am hearing. I don't do much gaming on the PC, I prefer my xbox that is rigged to my projector, with a proper 5.1 set-up. BUT, at night, when everyone else is asleep, my office is at the opposite end to the bedrooms, so I do watch movies and stuff in here. I'm not too fussed about 5.1 in the office, but could get close to it with just the speakers I already have kicking about, but most of all, I want to make use of my spare M1's.
So, first option.
It is the most expensive option. But does give me something else into the mix for another room. Is to upgrade one of my AV receivers elsewhere in my house. I haven't gone 4K yet, so my trusty Onkyo 609's (I have 2) have been fine for my 1080p / 3D viewing. However, I am considering a 4K TV possibly next year, so I could upgrade one of the 609's to a proper 4K receiver, and use the 609 in the office. Seems like overkill, but I could also feed my DJ decks through it, and get rid of the NAD 310 that I currently use in there too. I would have to hook them up as a zone 2 system though, as they use my B&W LM1's, and because of where they are located in the office, I couldn't get the sound "facing" me if they were set-up as just another regular source. There is no way to re-jig the room to get everything working in the correct direction really. I'd also most likely have to run it in pure audio or stereo direct mode, to reduce any lag when mixing on the decks. An issue I often have whenever I have tried to use my receivers for DJ-in. I'm not sure that this is best for my mixing, but probably the best solution for my PC & one of my other surround set-ups.
The problem with this option, is that it'll cost somewhere at least £500 to properly upgrade that amp. So wouldn't be able to do this for a couple months. But then will likely give me proper 5.1 hifi sound in my office.
Most likely looking at the Yamaha RX-A670 for the upgrade (at ~£599), but leaves me with an Onkyo TX-NR609 for my office.
Option 2.
And I just thought of this option half-way through writing this post, as I forgot I had it. I actually have another "spare" Av amp, a Sony STR-DG910. I use it in my garage, exclusively, and only in stereo mode, hooked upto a chromecast audio. I could swap this and the NAD around, and use the AV receiver in the office, and the NAD in the garage.
Option 3.
I buy another stereo amp to replace the NAD 310. I like the NAD 310, but it doesn't have a switchable A/B speaker set-up. So I could get another amp in there, that will allow me to simply switch between 2 stereo speaker set-ups. One for the PC, and one for the decks. Run off the same amp. Ideally I'd want an optical connection for the PC, but could go fine with a regular RCA connection from my soundblaster.
So this, I feel, would be best for my decks. And probably the best option for a "clean" sound from the PC. But does mean buying kit exclusively for the office. So I would be budget limited to somewhere around £150-200.
Probably the best contender here is the Pioneer A20 at £169
Option 4.
I stick with the NAD for the decks, and ditch the idea of running these B&W M1's for the PC. I stick a budget of around £100 and just get new PC speakers. Having a look on OCUK I could go 5.1 with something like the Edifier M1550 MULTIMEDIA 5.1 SPEAKERS (the C6XD 5.1 SURROUND SPEAKER SYSTEM would be double that, unfortunately). This, I'm sure would be great for the movies I watch in there, but also for the occasional games I play I'd think.
Or I stick with a better 2.1 system and go for something like the C2V 2.1 SPEAKER SYSTEM WITH EXTERNAL AMPLIFIER.
Or go down to 2.0 with something like: R1800TIII 2.0 STUDIO SPEAKERS RMS 70 WATTS (R1800TIII).
So, a few options to consider. I'm more drawn to the 3rd option, as it gets me something right now, and will probably be the best option at least with regards to my music listening from all sources in the office. Although the first option is probably more sensible. But probably not as sensible as the second option, as that means spending nothing. I might try that out over the festive period anyway, and see how it works for me as it'll be a zero cost option just now.
Any other suggestions as to what I could get, or what of the 4 options might work best for me?
Suggestions... Yeah. Drop the habit of starting your sentences or paragraphs with So. :) lol
It seems to me that you have some other options open depending on your flexibility.
From the sound if it you don't need much more than stereo and optical/coax digital for true 5.1? What's more important to you is the flexibility to run analogue or digital in either area.
By now you've worked out that Zone 2 from an AV receiver doesn't do that. Z2 is limited to analogue only. (It's like that for most sub £800 AV receivers.)
You're also looking for decent stereo music performance. That is easy for 2 channel amps, but at your budget they either lack the digital inputs or the power for decent dynamics in music. Current AV amps often miss the target with music compared to stereo amps unless you either spend a chunk of £££'s or set the performance bar quite low.
The answer to me seems obvious. A used AV receiver with excellent music playback credentials. It would be a bonus too if it had a feature to do a pseudo-cinema effect from just a pair of stereo speakers, and even better if it had the ability to do that with headphones too.
In summary then, A/B speakers with inputs for analogue AND digital in either zone. Coax and Optical connections. DD & DTS plus Prologic. Hi-fi amp quality playback. Some nice bonus tricks with surround from stereo speaker and headphones. Oh, and not expensive either as it might get replaced by an Onkyo sometime in the next 12 months. Under £150 would be great. Half of that would be even better.
I might have the very thing. :)
So. I'll try to start dropping so. I have already been told off, many years ago, for using lol too much, I think I have been reasonably successful in dropping that.
Well, I don't really need digital in the zone 2. That will be an analogue out of the back of my Allen & Heath Xone DB4 mixer. So zone 2 is fine being Analogue. So that should be fine with most AV receivers.
Maybe my Sony doesn't have a zone 2? In which case, that receiver is pumped.
Also, in that case, I might as well go for the Pioneer A20 as that will give me the musical stereo performance I desire. I would have to make do with an analogue connection between the PC and the amp, but that should make things easier for placing the amp as I can use a longer analogue cable. And it SHOULD have the power to drive my speakers, being that they are only the tiny B&W M1's and LM1's.
However, I am curious to hear what you have that fulfils all the requirements you yourself have suggested.
Another alternative is to just get powered monitors for my decks, and move the NAD over to PC duties. Doesn't do much for utilising extra speakers, but I could sell on the older LM1's and put that money towards the new monitors.
Sorry. Just found it there. I have replied in more detail to your trust. Thank you.
But I have decided that as I value the more direct, unprocessed nature of the stereo amp for my DJ-ing, I think that is the route I'll take, and suffer whatever I have to on the PC side. End of the day, whatever I get for this side will be a vast improvement over the onboard audio and X230 I have been using up to a week ago.
