A test here - http://www.thorneymotorsport.co.uk/ - click on Fuel test results.
I'll be conducting my own economy tests soon. Watch this space!
merlin said:Hmm. Test is dated August 06.
Think I'll stick with Vpower. That test is with Optimax (which was 98RON), whereas Shell's Vpower is 99 now isn't it?
This is the test I spoke about on the previous thread.Tomsk said:A test here - http://www.thorneymotorsport.co.uk/ - click on Fuel test results.
It was V-Power in August, just not marked as such I am told by someone who works at Shell. They stopped shipping Optimax Jun/Jul and it was all V-Power after that.merlin said:Hmm. Test is dated August 06.
housemaster said:This is the test I spoke about on the previous thread.
Simon said:Also Tesco 99 won't give you the economy benefit as it has less energy in it. The reason it makes more power more likely due it running 'leaner'.
Ethanol (Tesco 99 has 5% of it in, needs an AFR of about 8.9:1 for stoichiometric compared to normal Gasolines 14.7:1. Ethanol has about 30MJ/kg vs 44-45MJ/kg.
Ultimate and optimax both are similar as they are around 98ron and are what the car's are mapped to run on, as Lowe says
Will Gill said:I get my sensor lighting up like a christmas tree if I dont use V-power , im not doutful in the slightest that there is a significant difference in octane levels.
