hi i have an old abit ic7 p4
decided to replace heatsink and the problems ensued
first of all the processor stuck to the old heatsink on the way out, thats ok i thought so moved on to installin the zalman
however this proved to be more than a right pain in the backside
couldnt get both sides screwed down and the brackets kept slipping around
starting again by removing the sink and guess *** the processor stuck to the bottom again
i think the latch that holds the processor in place is knackered it feels quite loose and doesnt hold the processor in at all
is it broke? anyone experienced this? have a fix?
pls help
thanks
fonzio
pls help
thanks
fonzio
