reinstall OSX What Happens to Bootcamp
9 Dec 2006
@ManCave
If i have OSX Leopard on Drive 1 and Bootcamp on Drive 2 in a mac pro and say Snow Leopard Releases & i want to Reinstall OSX Snow Leopard Will it Auto Detect Bootcamp Drive Or Does it Vista64bit need to be reinstalled.
thanks
Sam
it will be more than likely the same as to doing a reinstall over the leapoard installation you currently have. someone here wil have done it recently. I'm betting everything gets wiped.
Different HDs/Partions?
If so doesn't matter, at all, your bootcamp will be fine.
Not that Snow Leopard is out anytime soon and by then you will be due a reinstall :p
