A Fresh Install
Ok, you’ve F-disked your HD, set up your partitions and you’re installing Windows, here’s the most common install order people use (inc me) on the forums:
1. Install Windows
2. Any Service Pack from Windows
3. Motherboard / Chipset drivers
4. Direct X update
5. Graphics Card drivers
6. Other Hardware drivers inc. sound, modem, LAN (etc)
7. Critical Updates from Windows Update
8. Install all your other programs and update them / set them up as you go
8. Full Defrag
If you have Antivirus and/or firewall software it is worth installing them early on, perhaps before you go online to get MS Critical updates. Do a Antivirus update early on too, to make sure u are fully protected.
Perhaps throw in a defrag for good measures after stage 4 just to get things running nicely from the beginning, but it’s debatable whether it will make much difference, certainly doesn’t hurt though!
