Hi guys,
I'm currently using a E2160 @ 3 GHz with enough volts and other settings to run it happily in Windows 24/7 without a problem. However, I'm still having startup problems...
Every now and then my machine fails to start up; the mobo reverts to its default settings and I have to manually change them back
It doesn’t do it every time, just every now and then? It's annoying though because I know the setup is stable - in Windows anyway.
A friend today suggested that I rule the memory out of the equation: I have 2GB (2x 1GB) sticks of PC5300 Crucial Ballistix.
I've the memory on manual settings, but they're now on auto.
Can anyone suggest some 'relaxed' settings that might be worth trying out?
Cheer,
SW.
Cheer,
SW.
