[Release] 7zip Icons Patcher
Don
21 Oct 2002
Parts Unknown
will make them look like this and will create a backup of the current ones in the Formats sub dir (not that it could break them anyway)
will work on every version of 7zip
http://bleddyn.co.uk/7zip/7zipIcons.7z
download this, extract it to a folder then run the bat file, need to log off and back on to see changes :)
if anyone wants any more formats done, let me know!
they're all 32bit with support up to 96x96
Terrific work mate. I do like the 7zip format - the archive reader is such a decent bit of free software, and it often compresses things to a smaller size than WinRAR. I've even used it in a professional capacity for software delivery at work :)
Thanks!
arty
Is 7z better then Rar with its compression algorithms? I've been hearing a lot about 7z for quite sometime now and its gaining popularity at a fast rate. I've only ever used Rar.
I was just about to post a thread asking for a freeware .RAR reader.. this looks as though it will do the job nicely. Nice app.
7z is better compression but slower, its getting a lot faster with each release tho!
i hate winrar and winzip because of their default context menu items which ruin the os layout! (easy to turn off i know)
7zip is clean and super fast at decompressing, also expands *.dl_ files quickly too, and the commandline version is flawless, and best of all its free!
Very nice work....thanks...
Yeah I prefer winrar because of the options it has when you right click on the zipped file....just easier
I use 7-zip because its a lot smaller as in what you can do, only the stuff you need and its free
Thanks...
Good job! :)
I have heard a fair bit about 7-Zip too but never bothered to try it as I am happy with WinRAR. I have just got a new desktop at work and that has 7-Zip installed so I am going to give it a bash on mine. :)
* Uninstalls WinRAR...
Cheers,
sfx
Got WinRAR temporarily disabled from common compression extensions, so I just installed 7Zip. Client looks nice if a little devoid of options atm. Going to give this a few months trial ta :)
Does 7-Zip support archive recovery? I just had a quick look and I didn't see anything but I may have missed it.
That is one thing I really like about WinRAR is archive recovery.
sfx
