OcUK Staff
We've just had a shipment of the new Cougar STX series of power supplies. The STX range are 80+ Certified 230V EU units which offer 115V 80+ Bronze levels of efficiency and conform to the EU regulations, offering stable and reliable power for those on a budget. Here is an efficiency curve of the STX550 that we tested recently: -
They are available from 350W - 650W, and the 450W upwards have 2 x PCI-E 6+2 connectors to support higher end cards. The STX series are ideal for HTPC, business and low/mid range gaming setups. They are in stock and available to buy now!
Cougar STX 350W 80 Plus 230V EU Power Supply - Black @ £29.99 inc VAT
The Cougar STX power supply series have been introduced to offer reliable, certifed power for your PC without breaking the budget. The STX series are all 80+ 230V EU certified, which meets 80+ Bronze 115V efficiency and conforms to the EU regulations meaning the PSU will hit a minimum of 82% / 85% / 82% at 20% / 50% / 100% load.
Alll Cougar STX power supplies come with a thermally controlled 12cm low noise fan, and a full suite of protections, including UVP, OVP, SCP, OPP and OCP. The single rail design offers stable support for power hungry VGA cards, and with 1 (350W) or 2 (450W - 650W) PCI-E 6+2 Pin connectors included as standard, the STX series is capable of powering the latest cards from NVIDIA and AMD.
The Cougar STX series of power supplies are an ideal choice for a office system build, a budget/mid ranged gaming PC or just to replace your aging unit with a PSU that is certified and meets the EU regulations.
Features
- High Efficiency - 80+ 230V EU certified (meets 80+ Bronze 115V efficiency)
- Capacity: 350W
- Compatible with the latest PC technology - Created for use with current and next-generation multi-core CPU platforms.
- Intel Haswell Compatible
- Ultra-Quiet and temperature controlled 120mm fan - Extremely low noise level, fan speed automatically regulated according to the temperature
- Integrated air inlet design - Optimal aerodynamic design that provides more silent operation
- Active power factor correction (Active PFC) - PF value up to 99%, provides clean and reliable power.
- Compliant with the latest EU guidelines - Energy consumption in Standby is < 0.5W
- Full protections with SCP, OCP, OVP, UVP & OPP.
- Dimensions (L*W*H): L140 x W150 x H86 (mm)
Connectors
- 1 x 20+4-Pin ATX12V/EPS12V
- 1 x 4+4-Pin ATX12V/EPS12V
- 1 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- Warranty: 2yr
Only £29.99 inc VAT.
ORDER NOW
Cougar STX 450W 80 Plus 230V EU Power Supply - Black @ £33.95 inc VAT
Features
- Capacity: 450W
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- Warranty: 2yr
Only £33.95 inc VAT.
ORDER NOW
Cougar STX 550W 80 Plus 230V EU Power Supply - Black @ £37.99 inc VAT
Features
- Capacity: 550W
Connectors
- 2 x 6+2-Pin-PCIe
- 6 x SATA
- 3 x 4-Pin-Molex
- Warranty: 2yr
Was [OLDPRICE] Inc. VAT
Only £37.99 inc VAT.
ORDER NOW
Cougar STX 650W 80 Plus 230V EU Power Supply - Black @ £41.99 inc VAT
nonl2br
Features
- Capacity: 650W
Connectors
- 2 x 6+2-Pin-PCIe
- 6 x SATA
- 3 x 4-Pin-Molex
- Warranty: 2yr
Only £41.99 inc VAT.
ORDER NOW
Features
- Capacity: 350W
Connectors
- 1 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- Warranty: 2yr
ORDER NOW
Features
- Capacity: 450W
Connectors
- 2 x 6+2-Pin-PCIe
- 4 x SATA
- 3 x 4-Pin-Molex
- Warranty: 2yr
ORDER NOW
Features
- Capacity: 550W
Connectors
- 2 x 6+2-Pin-PCIe
- 6 x SATA
- 3 x 4-Pin-Molex
- Warranty: 2yr
ORDER NOW
nonl2br
Features
- Capacity: 650W
Connectors
- 2 x 6+2-Pin-PCIe
- 6 x SATA
- 3 x 4-Pin-Molex
- Warranty: 2yr
ORDER NOW
