Remote access question
31 Dec 2005
Always on the M1.....
Is it possible to access my home (clarkconnect for what it's worth) server from inside my NHS firewall?
Don't want to waste my time looking into tunnelling and FTP/Web server stuff that I know naff all about at the moment if I'm onto a non-starter.
Would be nice and handy but they seem to try and block most of the fun things here - I'm still amazed I can get into these forums!
Cheers!
If you've got port 80 access (i.e. http, which I am guessing you have..) then you can get yourself a socks proxy (on the "outside") and tunnel whatever traffic you like through it.
I know you say you dont want to use tunnelling etc but to be honest it is uber simple to get working.
I use it to get through my schools firewall, I can forward any ports I like through it using Putty
You could always use TOR might get you through some firewalls.
I tried to do this the other day but couldn't manage it, I have done it before.
At work, to tunnel trafffic encryted through my home internet connection. I had to set my proxy in browser settings to 127.0.0.1 and when I browsed the web on the local computer (works) it actually fetched the web pages using my cable connection at home.
Using putty to tunnel
Any ideas/?
So what would I need to run on each machine then so that I can access the files?
I assume it's not just as simple as running Putty. How would I then copy files over?
And I also assume that Putty is only text based, so does that mean I would have to run command line rather than drag and drop to copy stuff?
