Remote access to whs
24 Jan 2003
North Wales
Hi
Trying to get remote access setup from whs2011. I have a tplink N750 router, when I select remote access in whs it comes up with setting up router and stays there, it even comes up with setting up router if I check the box to manually set up router. Anyone had this problem or know how I can get round it
Cheers
Fergin
log in to the router and do it your self, port 3389 i would recommend that you do it via a port redirect if your router supports it. or change the rdp port via reg edit.
then all you have to do is enable remote access via right click computer, and properties then remote access.
Thanks can forward the port, but when I right click computer, remote access is greyed out and wont let me select, if I do it via WHS 2011 remote settings it still hangs on the setting up router bit
Fergin
