- 28 Jan 2005
- Southport
Hi all,
Wiring a sub into my mates car and we are struggling to get the remote turn on to work.
We have tested all the cables and they are fine. We have put a little wire from the 12v on the amp to the remote on the amp to bridge it and that fine works a treat so we think the remote on the stereo is broke.
Its a Mk4 fiesta and I was wondering if we tap into the ignition or live feed on the stereo instead of using the remote wire would this work and not drain the battery? The stereo only comes on with ignition so I was thinking it would be ok.
Thanks
Pete
Thanks
Pete
