Just the Aziureus HTML WebUI?zen62619 said:1: You have installed the plugin
Password set.2: You have configured the settings in Plugins > HTML Web UI > Enable Password
Doesnt work. Just says unable to connect or similar in whatever browser i use.3: You have tested it internally http://localhost:6886 (it works?)
My router is set to forward ports 26000-26001.4: You have enabled firewall rules to port forward 6886 > internal lan > machine.
Closed Sygate, still cant access.5: You have disabled any inside firewalls?
.Actually thats wrong. Just because you have a router doesnt mean you dont need a firewall. Routers dont do outbound protection.zen62619 said:Seems to me something is blocking it, just install your internal firewalls because they are not needed when you have a router.
Already done all that.Follow this again but make sure SP2 firewall is OFF and you have no other firewall on.
1: Install Azurus
2: Install the plugin, and make sure you have configured the settings in Plugins > HTML Web UI > Enable Password
BoomAM said:Actually thats wrong. Just because you have a router doesnt mean you dont need a firewall. Routers dont do outbound protection.
Regardless, i stopped Sygate, but i still cant get local access.
And According to Azureus, the port its using, 6886, is perfectly fine. So its getting through.
IdeaS?
BoomAM said:Got it working through local host.
Changed the protocol from https to http.
.BoomAM said:Security.
Https is more secure than http.
Works on remote computers as well, asked my mate to check.
Thanks for the help btw.
My only concern now is security.
I might play around, see if i can change the default port to something a little less standard. Ive tryed a few port changes upto now, but it just doesnt want to work..
Maybe.zen62619 said:lol... a username and password should be sufficiant.
.zen62619 said:then I suggest you give uTorrent a go. with their webui
[Sniper][Wolf] said:How is that going to solve it?
zen62619 said:It's an easy application to configure, much easier than azurus..
