Remote connect problem across LAN
7 Feb 2007
I have two desktops and they are both running XP SP2. I can share a hard drive and view the drive but I cant connect using this method from the run command:
\\warpy\c$
I don't have any firewalls in use.
As above, very much depends on the error you get.
Also bare in mind you have to be a member of the local 'Administrators' group, or a group within that group - IE: Domain Admins to access a c$ share.
Hope that helps,
Use a password on the Admin account of the system your trying to remotely connect too and then try again.
