- 7 Mar 2005
If anyone could help it would be much appreciated.
I have just installed a copy of Userv so i can try to connect to my PC from work,
i am using a dlink router and on the Userv website it says that i may have to open a port on the router to work correctly. I have looked at the dlink website about opening ports, it says that you use the virtual server function, add a name, IP address, and the port number, then you click on apply, when i click on apply nothing happens.
Sorry its a little vague, but i really don't know what i'm doin when openin ports.
Sorry about any spellin mistakes but my little boy has pulled all the keys of the keyboard and i not sure where they all went back.
Cheers
Cheers
