Remote Control for an HTPC
18 Jan 2003
Expat in the USA
Hi,
Can anyone spec me a remote control, preferably bluetooth for a HTPC? Similar to say the PS3's Bluetooth remote?
Does such an item even exist ? Failing a remote a small Bluetooth keyboard with integrated mouse would probably do the job..
Any suggestions?
Any form of Media centre remote should do the trick. They normally come with an IR USB dongle.
The better ones even come with small mouse trackpads built in.
They range from £6 for the very cheapest ones to £100+ for the likes of your logitechs etc.
Is there an app for the iPhone that'll let me control my pc? Without too much fiddling?
Looking at this HippoRemote on the iPhone.. Only $5, anyone else use it? Got any good things or bad things to say about it? Before i blow away $5 of my hard earned cash. :D
What htpc software are you using? If you are using xbmc, the offical app on iphone for it is amazing.
VLC Media Player and I've found a VLC remote control player for the iPhone.. Still at work, but can't wait to try it out..
