Remote control for Yamaha AV amplifier
15 Oct 2017
I have a RX-V671 home cinema amplifier and the remote has finally packed up. I can use the mobile app. so it's not critical, however what would be the best route ?
The genuine remote is £35 online so does any one know of a universal replacement that will fully replace the old remote ?
I'm a bit behind on these things!
The volume button on my Onkyo remote has packed in after 7 years so I was on the look out for a replacement but they are going for about £25 which seems a bit steep for its age.
So I am going to try cleaning it later using the this guide I know its a different manufacturer but maybe worth a shot.
All the Harmony's will be compatible, on some (without screens) you may need to assign functions to odd buttons, ie you may need to assign Sound Style to the Info button or some such, but every button on your current remote will be mapable to any button on the Harmony.
OK thanks, I can do basic functions from app, but not things like run speaker setup or even bring up OSD in fact.
if it is a full replacement then it looks like I may be asking Santa for one of those then :-)
Yeah, best thing I ever bought and even better now I have paired it with Alexa. It's quite nice getting home and just saying "Alexa, ask Harmony to turn on sky" :)
But saying that mine is the Ultimate with Hub - so a bit more money than the more basic ones.
