Permabanned
- 28 Nov 2003
- Shropshire
I have a laptop running XP Pro, a desktop running 7 pro 64 bit and another desktop running XP Pro. All on a hard wired network via a switch
I can log into the Win 7 desktop PC from my laptop OK using RD. I can log into the XP desktop from the Win 7 desktop using RD. Should I also be able to log into the XP Pro desktop PC from my XP Pro laptop using RD, as well (not at the same time as being logged in via RD on another PC...)? The laptop doesn't see the Windows XP Pro desktop. Should I be able to add it somehow? Thanks. I still use XP Pro as I have legacy automotive software that won't run on a later OS, and I am not concerned about any security aspect as I have nothing of interest to others on any of these.
