Remote Desktop Connection to Virtual PC2007
27 Jun 2003
Reading
I am curretly setting up a media pc and configuring it for such use. Im using virtual pc2007 and am setting up remote desktop connection.
I have enabled remote connection options and created another account for remote connection (gave remote access also).
When trying to connect on the host pc it will go as far as loading the remote window and show the login screen but it will not login with any with any account set up in the virtualpc.
Now im not sure if it is a limitaion with vpc2007? but im thinking it has more to do with account settings??......
Help.....please.....
What do you mean 'will not login'?
Because if your sat on the host, running the client, then trying to remotely control the host, that only ever going to end in tears! youd end up remotely controlling your own session. Its effectvely like trying to RDC your own machine, just with a step in the middle!
However, if your trying to run concurrent RDC, then you will need to hack XP to get it to work anyway, and even then im not sure it will work
