14 Aug 2008 at 10:58 #1 Frapple Frapple Soldato Joined 4 Nov 2007 Posts 4,514 Used to open up full screen with the bar at the top, went odd yesterday, now opens up in a window, can't get into the start bar. What happened, anyway I can reset it's 'view'? Google does nothing. Thanks
14 Aug 2008 at 11:00 #2 Kol Kol Man of Honour Joined 8 Jan 2003 Posts 14,395 Location Ashby-de-la-Zouch Just expand the window, makes my RDP full screen then.
14 Aug 2008 at 12:07 #3 Frapple Frapple Soldato OP Joined 4 Nov 2007 Posts 4,514 Maximise = 3/4 of screen, can only see some of the computer, can't resize, same with in a window. I want it so it's a full screen app again, as in I won't be able to see my start bar and able to use alt + tab within the connection.
14 Aug 2008 at 12:20 #4 El_Watcher El_Watcher Soldato Joined 1 Apr 2004 Posts 2,981 Location Herts, UK If you go into the options before connecting, the is a display tab, with a slider. Move it far right which should be Full Screen.
14 Aug 2008 at 12:58 #5 Frapple Frapple Soldato OP Joined 4 Nov 2007 Posts 4,514 Woo thanks, it moved to 1600x1*** when I restarted a server yesterday, causing RDC to crash, odd. Thanks!
