Remote Desktop
25 Jul 2004
Hi Everyone
I was hoping that I would be able to connect remotely to my PC from work. The PC i want to connect to is on a home network router and the OS is windows XP Pro.
Can I possibly have some instructions on what I need to do?
Thanks
enable remote desktop on the pc, make sure your user account has a password, forwartd port 3389 to the local ip of your computer. Then connect to your WAN ip with the RDP client from your work pc.
That's what you need to do, post back what you're unsure about and someone here will be able to give you more details
How is it better than remote desktop? In RD I just type in my ip address and i'm logged into my computer. I can't see how that can be any worse than installing some third party stuff.
Agree with you. RD Works fine, why complicate it ?
RLBUHT said:
Hi Everyone
Thanks
you need to set a static local ip for your machine
(use "ipconfig /all" in a cmd window to see what you need to type in to get it all working, then type it in manually in the network properties, tcp/ip window)
choose something like 192.168.1.123 (replace 123 with whatever you want (1 min, 255 max)
look at http://www.portforward.com/ if you don't know what i'm on about..
says all you need there!
