- 16 Mar 2011
- Leeds
I am just looking for a little advice regarding wireless triggers for my Nikon D5100.
I am aware that the D5100 does not have commander. I own an SB-400 & SB-700. I know the SB-700 has the commander built in and adding another SB-700 or 900 etc will give me the capability to fire one of the flashes remotely without having to fire the main flash in SU-4 mode.
I have played around in SU-4 mode indoors and it seems to work pretty good (outdoors maybe a different story i'm not sure) but you have to fire the pop up flash or use the SB-400 on the camera to make the remote flash fire.
I would like to know whats the cheapest / best way to remote fire my SB-700 without having to fire the pop up/sb-400 flash on the camera. Will any of the wireless trigger systems that you can mount to the hot shoe work ok or are there good ones and bad ones?
I will be getting another SB-700 in time but I am just looking for a decent solution until then.
Cheers
Cheers
