- 19 Apr 2004
- London
I live on a ground floor flat with it's own side entrance that is lockable and currently has a 1 way audio entry system:
https://www.tlc-direct.co.uk/Products/DE901.html
It also has a remote lock fitted.
I'm thinking about switching this out to a remote system that I can use over the net to allow deliveries in while I'm away. I know there are a few options out there and I was hoping there was something that should be fairly easy to wire in to the existing 12v system and remote lock. I should be able to get wi-fi from there so I don't think I'll require any additional wiring.
Can anyone recommend a setup that would do the job?
