Remote install via iLO, slowwwww
26 Nov 2002
Romford
Hi
If there a reason why when remotely installing an OS via the iLO2, it only seems to transfer at 10mb/s, when the port is 100mb/s.
According to the switch, the iLO port is running at 100mb/s Full Duplex, but data is crawling along.
Cheers
It's always been the same due to it being an ILO session which has to get transferred from your computer / CD drive and then transferred over HTTP to the ILO then transferred from the ILO to the server.
Hence I only use it in an emergency.
M.
Probably best to try and setup some form of pxe booting, which OS are you installing on what hardware?
As the others have said - its damn slow. No way of speeding it up too :(
Seek alternative such as the PXE boot as suggested above.
I'm assuming the kit is based remotely ?
