Hi all,
My brother has toyota verso mpv, the buttons on the remote/key fob has torn and come off/lifted off slightly, the buttons still work (see pics). Is it possible to get the buttons repaired/replaced or would he need to get a replacement key fob?
If his needs to get another key fob, would it be via a Toyota dealer and what is the approx price or can you get off auction sites or alike? Not sure if it makes a difference it one of the cars where you don't need to put the key into to start the car but insert the fob which has also has small key inside it
https://ibb.co/10wm8gS
https://ibb.co/w0rkDkZ
Thanks in advance
Thanks in advance
