Okay, Remote Play over the internet is ******* me off, before the Remote Start function came into play I had it working, but now even if I don't use remotestart and just leave my PS3 on, I can't connect externally.
But It'll work if I try from my connection, both Locally, and Externally. I've upgraded my WRT54G-S with tomato custom firmware, and uPNP works now, I can see the PS3 opens the ports fine, and get Nat Type 2 okay.
But when I try connecting externally It comes up with Connection to the PS3 has timed out?
Before anyone advises to reset PSP/PS3 to default settings, I did this. Twice now.
Basicly, I'm in tune with routers and settings, I just think it's the router being ghey. What would really help, is if someone with a working setup tell me what router they are using and so forth. Or if they have the same router to tell me the settings they used.
Thanks!!
Thanks!!
