- 31 Dec 2003
- Barrow-In-Furness
Is there any software which can probe across a network and execute a remote shutdown if a user is NOT logged in?
Wouldn't it also mean having to force a certain Windows Start Menu so the Log Off button is hidden etc?
Not quite. You'd either force it through Group Policy (assuming you are on a Windows Server 2000 (or greater) Active Directory Domain, or through local security policy. The options can be found in here:
User Configuration > Administrative Templates > Start Menu and Taskbar
