Hi guys, I work for a small education team that help schools
We have currently been using a program called unltra vnc http://ultravnc.sourceforge.net/ it’s a great little bit of software, the only trouble is it requires the user to download the files and then install it, we wanted to use some sort of free single click remote support that will allow both the user and us to see the same screen. Windows remote logon is ok but that blocks the user, who is often fairly unskilled in IT as they are an school receptionist. They can have IT support but they have to pay for it, we want to be able to make there job easier and help them in a better way (i work for a small department in the Southampton council)
So can anyone recommend a good bit of VNC, software, perhaps something I can create a database with or a simple single click front end for the user?
Any info would be good as it’s all new to us
