Remote Wipe
17 Sep 2007
Liverpool
Hi everyone,
Does anyone know of software which can do the following?
* Require USB Key on boot
* Encrypt entire drive
* Remote wipe if the computer hasn't contacted the server is X days?
I know Bitlocker can do they first two but I'm really struggling to find one that does the third.
Thanks
You could have a system of scripts/scheduled tasks for the third but it'd never be a complete wipe. If encryption is good enough then surely a wipe isn't necessary?
Encrypt the drive with bitlocker, additional hidden encryption partition for super sensitive data with Truecrypt etc?
Probably I see with third one would be that the people would have to have got past the lack of the USB key and encryption to even start the PC up, otherwise it's turned off. Assuming they did get past those you could simply have a back door into the PC via remote access and initiate some sort of partial wipe manually.
