Remotely 'Removing and reinserting' USB Device
20 May 2004
I'm logging onto my computer remotely and the bluetooth dongle that is plugged into the USB port is playing up. The only way I have found to correct it is to physically remove it from the usb port and then reinsert it.
Unfortunately I am not in front of it. Is there a way I can do a similar thing remotely? The computer I am connecting to is running Windows 7 Basic (or netbook version, i'm not sure what it's called). I am using logmein to remtely connect to it.
Many thanks
Fetster
I meant to add that I have tried uninstalling and disabling the dongle in Device manager and the device came back with the same problem when reinstalled.
thanks guys. I will try the usb power reset program. I have tried to disable and reenable in device manager but it comes back with the same issue.
THanks again
I am unable to get the USB power reset program to work correctly, I don;t think it is compatible with Windows 7.
Unfortunately I can not find any way of turning off then turning the usb ports back on in the control panels power options, can somebody point me to the right place please?
I have tried to uninstall and reinstall the device in device manager but it reinstalls it with the problem again.
I thought of buying a usb powered hub and putting a timer plug on it that turns off for 15 min twice a day. If the power was to be turned off at the hub, would the device turn off or would it draw the power directly from the computer?
