Remove bottom panel be quiet 900 pro
7 May 2004
If anyone has this case do you know how to remove the bottom panel? I want to mount a radiator on the bottom but for the life of me can't work out how to remove the bottom and my Google skills aren't providing me the answers I'm looking for
Good luck, I snapped the fixing mounts on mine trying. Mine now just slides back and forth easy.
Still don't know how to do it properly.
There are two small screws about half way along the bottom of the case insides. Near the edge one per side. Once you get these out it will slide forwards I think then lift of.
Sorry for the necropost, but I just wanted to thank you for this information. Absolutely spot on!
(I have the Rev2 but it is the same in this respect)
