Remove cement from block paving?
I got some concrete/cement remover to do mine, it has hydrochloric acid in it so you need to be careful
It does take it off but takes a few goes depending on how ingrained it is
Nope don’t do that as if you splash yourself you’ll get burned lol
I followed the instructions , dampen the affected surface , dilute cleaner as necessary in a plastic container and used a cheap 3 inch paintbrush to gently wipe in on
Left it 10 minutes then rinsed off with hose
For safety rubber gloves and goggles are recommended but I just made sure I had the hose to hand if I accidentally got any on my hands
