- 5 Sep 2005
- Northern Ireland
Does anyone here know if the wee electric window switch assembly in the drivers side of a 2001 polo can just be pried up and out from the door card? Or does the door card need fremoved to get it out?
The reason i ask is that my drivers side switch for the passenger window appears to have shorted somehow, i must have got it wet or something. When i got home tonight and removed the key from the ignition the dashboard lights, ashtray lights and switch led's didnt go out like normal, they just remained on.
After fiddling with a few switches i found that the passenger window switch wasnt working correctly, if i touched it at all the passenger window would wind down (the switch hasnt worked in months) and the other interior lights would go out. Then whilst holding it down and pondering how to fix it, smoke started to some out if the switch, which was a bit alarming, so i figured the best thing to do would be to disconnect the car battery so the car doesnt do an inpression of a bonfire overnight and see if i can pull out the switch in the morning.
Anyone know if i can just lever the assembly up and out without breaking something?
