* rc.0 = The rc.0 file is a symlink to rc.6
* rc.M = The init script for multi-user runlevels 2, 3, and 5
* rc.K = The "administrative" runlevel, single user mode
* rc.S = The system initialization script
* rc.4 = The init script for runlevel 4, which is the runlevel that automatically boots into the X Session Manager of choice
* rc.6 = The script executed by init when rebooting or halting the system
I'm gonna try it I guess ssh/httpd etc aren't needed for normal running of linuxsunrpc
auth
ipp
X11
Originally posted by r00t
you can comment out any services you dont need in /etc/services and your /etc/inetd.conf (or equivalent). Theres a way to stop X11 (X-Windows) from opening a port, its a line you have to add in one of the conf files but I cant remember it - anyone else?
Originally posted by Shak
The way I did it for a quick fix was to get it to execute a script on my login that kills the services that i dont require. Alright it may be a bad way to sort it out but it wasnt my box and I only had 5 mins
Shak
Originally posted by mortals
Doesn't that mean the services would start and then stop ????
I removed PCMCIA also cos that seems to take a bit of time on startup![]()
