Remove tool-less bay brackets from silverstone f02
26 Dec 2008
Scotland
Anyone know if the 'tool-less' 5.25 bay brackets can be removed from the Silverstone Fortress 2?
I'm not exactly sure how they are attached to the case but id rather not damage the case or the brackets trying to remove them.
Could you post some pics, but i've read most SS cases are all fixed cradles.
I can't confirm that thou as i don't have a SS case.
yea they come off its the same ones in my ft01 you have to unscrew them from the inside which is a bit fiddly but doable none the less took them off my ft01
