Remove window.alert after interval
27 Dec 2005
Bristol
Is it possible to automatically ok/remove/override an JS window.alert prompt after a set amount of time? I've tried using setInterval to reset the alert to "" after 5 seconds but it doesn't work and my Googlefu is failing me (delete/remove etc are too vague terms).
OP
27 Dec 2005
Bristol
It's just a simple thank you alert, but it's on a point-of-sale system so I don't want it blocking the page after the customer has left.
And yeah I'll probably have to look at a lightbox or div popup but it's far more faff than removing an alert (if it were possible!).
12 Dec 2009
Gloucester, UK
Yeh alerts are very obtrusive and not very user friendly. I would definitely recommend a modal as per suggested above, which is essentially making a div appear over the top of the site.
AJK
AJK
8 Sep 2009
UK
Javascript alerts are absolutely not the right way to do this.
Really? Many big frameworks will give you a modal dialog in a few lines of code, and it's not difficult to roll one yourself. Or just display a message somewhere on screen which clears itself after a few seconds. If it's "just a simple thank you alert" it doesn't seem like something which needs to take over the whole screen, does it?
