Removing a moderator in phpbb...
26 Feb 2004
Hampshire, England.
Hi guys,
I've had a recent shake up of personnel on my forum and I'd like to remove a user as a moderator.
I've followed;
Forum Moderator permissions can be assigned to users by clicking "Users' forum permissions" from your ACP Permissions tab, selecting a user, selecting one or more forums from the list, and then selecting "Moderator permissions" from the Select-type dropdown.
but even after changing their permissions back to 'Not Assigned', they still appear as a moderator on my board...
Any ideas? I'm guessing some kind of global setting has been used in the past? Strange though because no groups are active :confused:
I don't use phpBB myself, so I'm not overly familiar with how usergroups/permissions work for that particular board. But it sounds like you've removed their moderator permissions from the individual forums but not removed the user from the overall moderator usergroup.
Make sure their primary usergroup is 'registered users' (or whatever phpBB call it).
